Carburetor Suggestions for Turbo 231?
231T
I have a 1983 231 turbo from a T-Type Regal.
The engine was in rough shape, but now has been machined and I would like to pick your brains for recommendations for a carburetor, as I wish to keep the draw-through turbo setup. Unfortunately, the original 4-barrel feedback quadrajet has been beaten to bits, and the computer was missing when I got the motor.
I've been advised to look into quadrajets or other 4-barrel carbs with a vacuum secondary to help account for the change of pressure under boost.
Any feedback would be great!
You'll need a Holley carburetor that is boost referenced and a Quadrajet to Holley adapter plate to mount it on the upper intake manifold. You'll have to speak with Holley or a carburetor specialist to get a recommendation and one set up correctly. There is a small raised pad on top of the '82-'83 aluminum intake manifold in the correct location needed that you can drill and tap to screw in a fitting to get a vacuum signal for the Holley to work. Beyond that, you still have several problems to overcome. Without a computer, the '83 distributor won't work. You'll have to source one for a non computer controlled engine. These carbed draw through turbo engines are prone to detonation. Without a computer with a knock sensor hooked up to retard timing , you'll have to play it really safe with boost and timing. Especially on regular pump gas. Or a company called J&S Safeguard makes an ignition system that has a knock sensor.
Definitely look into J&S Safeguard to handle ignition. There's an older version of a holley carb that has spread bore already if you wanted to go that route without adapters for hood clearance.
I have made new discoveries about my engine and the car that now accompanies it.
Both are 1981 (non-matching), and I have a Turbo Control Center on hand now. I had my old quadrajet looked over by a former turbo Buick tech, and he found the carburetor is fine, save for needing rebuilt.
I've been looking for a gasket set, but so far, none look like the gaskets I pulled out of it. Does anyone know where I can find gaskets that fit an '81 E4ME Rochester?
Nice catch matching up that gasket kit before installing them. Are you trying to use the 78-80 turbo control center with a CCC carb? The 1981 carb would be computer controlled and won't work with that module. You would need an older 78-80 carb that enriches from vacuum coming from a PEVR valve in the intake manifold.
Truth be told, we aren't sure what year the TCC came from, but the carburetor is original to the motor. I've been told there should be a module under the dash somewhere, but I haven't been able to find it yet.
That being said, the dash is slated for removal to prepare for the new heater and A/C system.
Is the wiring harness still in place? If so you could follow it into the dash. But if the harness has been cut you'll probably never find a replacement. I have a couple NOS CCC 4.1 carbs that I think would work fine if the harness is still there. Have a few non CCC turbo carbs too but no extra PEVR valves to make them work properly.
