Well if some of you remember I posted about an issue with my motor, and I was not in the US when the motor began making noise when my father was taking it to storage.
The pictures below show it was not a blown motor, but instead broken rocker shafts, and if you can believe it, my father was able to keep the motor running on 3 cylinders for about 4 miles to get it to storage.
Few questions for the experts:
1) Are these the TA heavy duty shafts, or are they the stock units.
2) I know the shafts are prone to breaking from reading the posts on here, but to the bolts usually snap off as well?
As you can see from the pictures the pushrods are not in the correct positions, and they are not seating into lifters. I am wondering if they may have pushed out of the block and are sitting in the intake valley (will pull the intake later this week, just wonder if it is possible.
The cam is a Lunatti 200/200 and I was not sure if I want to replace it now as well. Once I get the intake off and see how bad the lifters are, I may go with the heads and cam, or if there is glitter in the oil filter, then I may be calling Don Cruz to see if he can work some magic...
Thoughts?
Thoughts?
