Cars with 325's on the rear
Yeah, I was surprised even to see people saying that 5.5" works with only a notch.
Yeah that'll work fine. Rt now I have 5" BS with a notched frame & plan on getting some with 5.5" BS with the same tire to see what happens :eek: But 6" ?? I'm not too sure, somebody who has done it might have to chime in on that 1 !
1BADTT- they re some beautiful rims!
Thanks 4 the compliment !! :cool:
Sweet ride !! :eek: Do U have GNX flares ??? :confused:
Thanks. No, There stock body panels.
Are those wheels powdercoated? I wanted aluminum rims but don't like the look of all Chrome wheels, and didn't see any drag wheels available in black.
No, I had my painter friend paint them for me.
werd!
You know it is pretty bad when you use someone eles's car for you desktop wall paper.
Just simply a beuatifull car....
What is the back spacing on your wheels?
All this time I had the 8's car as my wallpaper and this car just changed that. What a beautiful machine. :eek:
Thank you very much for the compliments. The wheel is a 15 x 10 w/5 B.S.
You can see a few more pix of the car here.
http://www.turbobuick.com/forums/stage-ii-tech/219679-its-running-2-2-1-years-later-w-pix.html
Wow now I have a new screen saver.
ANy tire rub problems with your setup? I am wanting to run a 5 1/2" backspaced wheel and was about to buy a 295 tire now I want a 325..
I know the lip is going to have to be massaged but I want the car down on the tire like yours if not lower.. Do you think there is a chance?
BadTT and BAGN, no notch correct??
I have yet to get mine on but after seeing more pics of 325's on stock non notched frames I can pull it off, I had the flares extended for this very reason.
Pic is 295/50 on a 10" wide 4.5" B.S.
My frame rails ARE notched. These tires will not fit under the body without doing notching.
that is the tire I am going for..Thanks for the heads up, I am still going to go with the 5 1/2 bs so I might not have to roll the lip very much...
Thanks a million!
Mine are also notched & lip rolled !! BTW Drag Radials r a whole diff ball game even if they're the same size # !!
Thanks a million!
Boostedbug, I have 2 choices...Either use the 295/65 tire or the 325/50 tire. Either way I'm getting a set of wheels with a 5.5" & I"ll try both to see which 1 looks better. I'm still a little inclined toward the 325/50 tire though ;) Post some pics of your set up when your done !! :D
