Cas stock location IC . Any pics of one bolted on the car?
GBGN1
BP Performance Transmissions LLC
Missing the spacer from the passager side aluminum bracket and just want a heads up. I'll have to figure something out.
There isn't a spacer. The bracket goes against that special bolt, then a nut, then the plastic ALT conduit bracket.
What about the bottom bolt on that bracket to engine?
So there's no spacer for the bottom stud. Has to be
YES there is a spacer on the top bolt going to the water pump!!! As a matter of fact CAS gave you a longer bolt all g with the spacer !
Oops. I missed the part about it being a DeQuick unit.
That's going to take some fabbing. You might be able to find something to use if you have a real hardware store local to you.
Yes earl that's what I had to do. Longer bolt and steel spacers. It will work. There not making these parts no more!
Thanks, I ended up getting some steel spacers and it worked out good. Thanks
