Just installed Casper's P/N 102049 ( pass-thru sender ) and P/N 102046 VSS converter module, I have check and rechecked the wiring to the instructions and according to my scan master, i still not reading and MPH at the ECM. I have a Auto-Meter P/N 2694 mechanical speedo, that still works. I do have 12 vdc going to the VSS converter module and 102049 sender, the brown wire from the VSS module is going to pin A10 ( speed sensor ) on the ECM.
Has any one used this set up before ??? Or am i missing something. I will wait till i hear back from anyone, before contacting Casper.
