Cat & Dump Pipe Set UP
3.8L V-8 eater
Hi, to all :)
I have a cat converter and dump pipe both stainless steel....The cat is used and the dump pipe is new never used....It comes with a new 3" stainless v-band clamp...This is so you can weld the v-band on the end of your down pipe and to the end of the dump pipe.....No more PITA slip joints....The cat has the v-band welded on already....You will be able to go from the cat to the dump very quickly once you have the v-band welded to the end of each piece....Dump comes with hardware as you can see in the pics!!
$180.00 plus shipping for everything....If using Pay Pal add for the fees or send as a gift
Thanks!!
Great set up, I put V-bands on my cat & cut out a few years back, they work great!
Ok dump pipe is sold!!
Will sell the cat for the 85 shipped and include the one v-band for your down pipe and the clamp!!
