turbobooster
- Nov 12, 2002
Finally installing my new exhaust and I want to install the cat hanger as well but I'm not sure how to go about this the right way or easiest method I see the 2 bolts where I will b mounting it but not sure how to go about it ? Do I remove the 2 bolts then carefully jack up the end of the transmission to slip in the cat hanger? Or do I need to loosen the whole rubber mount on the crossmember and the 2 bolts? Any tips suggestions are greatly appreciated thanks
