SCOOBY DOO
BASED CANADIAN PATRIOT!!
- Feb 18, 2007
.030 over 109-CEA 6262-Stock compression ratio-Champion iron heads-Champion stock appearing intake-3:42 gears-AC 16930 convertor-Alky. What would you guys run for a cam?
SignUp Now!What kind of spring pressure are we dealing with? The converter is going to eat up mph if you run high cylinder pressure. If you had enough spring i know exactly what id be running. It will extend the rpm a few hundred more than the common "stuff" you see posted about. 1.65 rocker ratio would help it too.
Your converter isn't even close if you're at 5850 and only 119mph trap. When my car went through at 138+ it was barely over 5900. You're limited on cam profile with a flat cam. To gain a big advantage you'd need to go with an aggressive roller. You should be at 122.5mph if you are at 98 in the eighth.Brian I'm currently running a 204/214 with 981 springs. The car runs a consistent 11.5 at 119 with 23 PSI with Erics 5.7 chip on aggressive low gear timing mode. It's coming time for an engine freshening up...so I'm curious if a different grind of cam would be better. Thanks to everyones responses. Oh...the car goes through the traps at 5850...and stock rockers.
No.The engine is out of breath that's why your eighth to quarter pickup sucks. A converter swap is worth about 3 mph here without even turning the boost up. Shifting later will give more drop but it will further slow the car down more.
You will drive into the converter even harder and the problem will be magnifiedHow about bumping the boost to 28-29 pounds from the current 23 PSI...or will that not help because the engine is already out of breath.
