SignUp Now!Do they make one for a roller cam? and what if block was line honed? Or is that why cam gets pushed up in cam journal.
Donnie, from the pics on your web site it is hard to tell if the gear drive will clear the pump shaft drive for a stock-type oil pump.Did you ever do a mock up with a stock timing cover?
It appears you do not have this situation with your dry sump system.
