champion fuel rail to use with external regualtor
norbs
Classic fast, XFI, SPortsman & MS3 programming
Looking to trade a champion fuel rail with stock regualtor for external regulator style
thanks
I just cut the end of my champion fuel rail off and tapped it for a npt thread,then used a npt male x -8 an adapter,worked perfect
Just cut it off Norbs and tap it with 3/8 thread for the Russell fitting. I did mine.
I did the exact same thing as ttypewhite,sorry i should have posted that i used a 3/8''x -8 male adapter....
Thanks, everyone, I'll just cut it off and tap it.
It wasn't easy to tap the hole is just a bit too tight, but i did it very slowly. pic below.
Looks good Norbs, and it also appears that you are starting to listen as well:biggrin: Good to see you have ditched the sheet metal monster for something more practical for your application. Good for you man. I hope this thing makes BIG power, God knows you deserve it.
