1-2 shift at 5150 and drops to 5050. 2-3 shift at 5200 and drops to 5100. What upgrade should I consider to get another 4-5 tenths off my time in the quarter? I just read a post from dusty that he likes to see a 600 rpm drop at the shift point. I am just wondering if I should restall my convertor now before I put this car back together.It would depend on what rpm you shifted at to determine the drop. If it's dropping to 5200-5300 after a shift it sounds about right for what you have. You mentioned you felt it fall off in the quarter. If it's picking up close to 25% mph in the back half it's not falling off. 102-106 is a huge range for eighth mph. 102 should net 127mph. 106 should be 132.5mph. So a 10.5x vs a low 10.20. If you're running out of turbo gains will taper off as boost increases. If exhaust pressure is increasing at close to 1:1 compared to manifold pressure it's not out of turbo. Id expect exhaust pressure to be in the low 40's at the end of the pass. You're definitely not out of head.
BPE2013@hotmail.com
