87WE4BOOSTED
I NEED MORE BOOST!!
- Jul 14, 2008
I just purchased a new set of champion irons set up for a roller cam. I know Tom installed K-Motion 1.265 valve springs. I will be using a Webber 212/206 Billet Roller. My question is, will these valve springs work using this cam? Or should I have them replaced with what Webber is selling to use with their cams? I know they are selling PAC springs but they have two different styles. Should I keep the ones installed or choose one of these?
Any help would be greatly appreciated.
OD Outer: 1.244
ID Outer: 0.860
Damper: Yes
ID Inner: 0.770
Installed Height (Valve Closed): 125 @ 1.750
Open Load (Valve Open): 350 @ 1.250
Spring Rate: 450
Max Coil Bind: 1.100
Max Lift: 0.550
The other is:
OD Outer: 1.260
ID Outer: 0.860
Damper: Yes
ID Inner: 0.770
Installed Height (Valve Closed): 140 @ 1.750
Open Load (Valve Open): 410 @ 1.200
Spring Rate: 540
Max Coil Bind: 1.115
Max Lift: 0.550
OD Outer: 1.244
ID Outer: 0.860
Damper: Yes
ID Inner: 0.770
Spring Rate: 450
Max Lift: 0.550
The other is:
OD Outer: 1.260
ID Outer: 0.860
Damper: Yes
ID Inner: 0.770
Spring Rate: 540
Max Lift: 0.550
