You need a piston stop with a degree wheel to find tdc. The piston dwells at tdc for a few degrees. With the piston stop you can go forward and backward and half way in between the unswept area on the wheel is true tdc. Then you can check to see if zero is actually zero on the tab. If it's off you can take note of the amount or alter your timing tab so it displays zero at true tdc
