Just a quick question... based on removing the canister behind the driver side headlamp to fit new air filter.
Is it ok to remove it entirely, and cap off both the lines that the two hoses fit onto? Or should they be connected with a straight piece of hose?
I'm not sure if it will have any effect on drivability or not. I will re-install it for inspection and emissions purposes come the time.
Will having the lines capped off cause any kind of excessive vacuum in the tank, or vapor lock? TIA
Just did this procedure, and hope to have some clarification before I drive the car to work tomorrow morning!
