SteveZ82
- Mar 31, 2019
I recently just got back from a 600 mile trip in my GN. Car ran fine. No issues. Until I boost. Now, granted we were stuck with 91 octane but I ran some booster to bring it up one night because we were going to do some pulls in our cars. I notice that when I boost, my wideband afr pegs to 10. Scanmaster mvs are 820-850. I was getting 10 degree KR. Now I know I’m super rich so I’ll adjust that, I just can’t solve this issue. Also, I’m not spooling too great. I used to be able to smoke the tires but no more. I'm trying to remember when it started running this rich. It's either after I replaced the O2 sensor with a Bosch (I'm going to throw the old one back on, I replaced this chasing another problem and the O2 wasn't it) or when I bumped up the new FPR to 41 psi line off or after I deleted the Cat. I have a brand new pump in the tank as well with a hotwire kit. Both racetronix parts (240LPH)
One of the guys I was up with brought his 81 twin turbo el camino. He's a master mechanic. That car is insanely fast. Anyway, he gets KR because of a lifter. Now, I have a lifter slightly ticking so not sure if that can be in the same frequency to set off the KR sensor. Also, the turbo shield will rattle when cold. I'll post some numbers I know now.
Boost set to 18 psi
TT 5.6 chip set for 93 octane, 42 lb injectors, 16-18 psi. Default settings.
In boost, between 16-18 psi, 10 degree KR. If I boost it at 14 psi it seems fine (not WOT). At top boost, between 820-850 mv on the Scan master. Pegged at 10 on my AFR wideband gauge.
cc counts are between 5-10 every cycle when cruising. BLMs at 117-120 cruising. Not sure where hey are at on boost.
180 degree thermostat, I run at about 185 all day on cruise in hot weather. I'm debating putting in a 160.
I'm not blowing any black smoke but the tailpipes are black inside. I don't race the car as it's mostly a cruiser but do want to boost every now and then because it's fun. I just want to do so without blowing anything up. Could this KR be caused because it's so rich? I really don't hear detonation but I could be wrong. I wanted to get my AFR up to like 10.8 in boost or like 780mV.
I think this is a matter of just getting the right tune and the right gas but wanted to see what you guys think.
Boost set to 18 psi
