88S10Durango
- Sep 14, 2007
Hi all ,I`m new & was told this is the place I might be able to get some answers on my 200 4R. I have a 88 S10 ,267V8 with a 200 4R ,all I could find out about the tranny is that it is a 1983 & had a diesel in front of it ,I put the B&M Street & Strip improver kit in it ,the trans shifts through the gears nice ,will downshift into first most of the time depending if I`m going about 10-20 mph or slower ,I`ve adjusted the TV cable as specified ,but the shifts especially 1-2 are very soft ,feels like a stock tranny shift ,here`s what I need to know , when I installed the kit as per instructions I lost the 3 lower ck balls that go into the lower part of the valve body part closest to the pan ,also I believe it was the 3-4 accumulator valve thingy that has 2 springs ,a upper& lower one that I put the spacers in from the kit ,anyways the spring that was closest to the pan side with the longer spacer was broken ,but I put it in anyways ,( bad me ) can tese trannys be run without those 3 ck balls and what effect is the broken spring having on anything? I wanted this kit to give me a firm almost hard 1-2 shift to bark the tires but am wondering if those 2 problems are causing my soft 1-2 & 2-3 shifts ,pls can anyone help me ,, Bill..
