austinibew145
- Apr 7, 2008
no additives. i have put 93 in 2 times. all new system.
SignUp Now!no additives. i have put 93 in 2 times. all new system.
Then I would focus on where you are buying and what they are doing if you can find out. Have you pumped any into a perfectly clean GLASS jar at the station to see what color it is? (It will normally be slightly yellow if the gas portion is normal pump gas and perfectly water clear if made with a low sulfur C5 pentane type of natural gasoline- it will be the former one that will have an additive in it). It may be that all of it around you is made with pump gas- if so the variation between stations and your issue will vary according to what terminal additive is used in the gas portion assuming my theory is correct. The E85 should always have perfect clarity- never any murkiness- with any fuel, it should sparkle in bright sunshine- if it does not- it does not meet specifications. Murkiness can come from entrained sediment, water, dissolved gums, additives, etc.
There's a good article in the January 2011 issue of Hot Rod magazine that discusses the rubber hose breakdown issues caused by E85 and other newer fuel additives. The data in that article backs up the studies done by the "mad scientists" at Turbo Farm West which shows that heat, when combined with E85 is a killer to the old-school style rubber hoses. According to the article, it appears that teflon-based hoses is the way to go.
Since the 1970s, most non ethanol gasoline sold has a component called MTBE (methyl tertiary butyl ether) added to the base gasoline to increase oxygen in the fuel, boosting octane. Though this additive is being phased out due to concerns over pollution of drinking water aquifers, it still is in use in many areas. Mixing ethanol with MTBE fuels creates a gel-like substance that gums up fuel and combustion systems.
One of the barriers to the production of ethanol from cellulosic biomass is the toughness of the cellulosic structure, and its resistance to chemical and enzymatic hydrolysis and insolubility in most solvents. Accordingly, pre-treatment such as steam explosion to break down the structure is a necessary first step. Now, researchers at the Japan Agency for Marine-Earth Science and Technology have discovered that cellulose undergoes a transformation from a crystalline form to an amorphous gel-like one very similar to a starch gel in water at high temperature (320° C) and pressure 25 (MPa). 2 Comments
