Need to move some parts fro a friend....
Here we go......Local pick-up for now Offers accepted on parts not marked Firm.
(2) "BRAND NEW" Mickey Thompson 295/50/16 Drag Radials.TIRES ONLY I mounted them on new Classic Industries GTA Wheels. ( ZERO MILES...NEVER DROVE ON THEM ). Fit was a little too close for me, and I did not want to use spacers. I decided to go with a smaller tire. There are a few turbobuick.com forum members who say they are using these tires without spacers...just didn't work for me.
I paid $213 each for these for a total of $426.   I need to clear the garage and will sell them for $300 FIRM.
(6) USED 42.5 pound injectors with two matching TURBO TWEAK  CHIPS. (One for Alky is: 5.6  6043  23-21 Degrees 21-24 PSI)  The other is: 5.6  23-21 Degrees 20-24 PSI $175
(2) NEW never used Red Armstrong "RACE 009 F7599H"   107 CHIPS (Designed 22 PSI boost or more). Never Used $30
(1) USED PIT BULL CHIP  (TA137L-528SDL) $25
(1) Brand New EZ-LINK AUTO XRAY Diagnostic SCAN TOOL FOR GRAND NATIONAL and GM VEHICLES 1983-1995   OBD-1 12 PIN CONNECTOR  $50
(6) New Sorensen injectors for a stock 1987 Grand National. New in box...NEVER USED. Part# 800-1011N $175
(1) Gray  2 1/16 single gauge pillar pod $20
(1) New GNS 2 1/16 Three Gauge Cluster That mounts above radio. Color is GN GRAY. Never used $75
(1) New in box  2 1/16 VDO Water Temperature Gauge.  Never used. $40
(1) 1987 stock intercooler and shroud with 32K miles. Intercooler worked well when it was removed from car. Shroud is torn on one corner, but is repairable.
$100
(1) Auto Meter hood mount fuel pressure gauge. ( NOT FOR GRAND NATIONAL ) $35
(2) MOOG stock replacement rear springs for 1987 Grand National with less than 250 miles.$60
(2) Rear Gabriel Gas Ryder Shocks with less than 250 miles.$40
(2) Stock Used 1987 GN Rear Lower Control Arms $30
(1) Stock Used 1987 GN Rear Sway Bar$30
(1) Used Factory 1987 GN Coolant Overflow Bottle $10
(1) New Powermaster Accumulator Ball.....(No miles). I installed it on my funky acting Powermaster, Then decided to switch to vacuum brakes. $50
(1) Used GM Mass Airflow Sensor with less than 250 Miles....EXCELLENT
 CONDITION. $75
(1) Used Autometer 3411 Fuel Gauge complete with cup and adjustable exterior hood mount band & bracket 1-15 PSI (For carbureted cars...not for GN) $50
(1) New top of radiator mounting plate. (has 4 small holes drilled in it). GM Part# 22506345
(1) Used stock 1987 Turbo Shield / Cover.  Needs a good sanding / refinishing $50
(1) New Stock Down Pipe for 1987 Grand National. Never used $$$ offers
(1) Red Metal Flake Old School Helmet $$$ offers
(1) Used Powermaster that worked fine until I started the car up after a long winter. The brake light came on...it started smokin'....I switched to vacuum brakes...END OF STORY! $100
