I have a basic recipe car with a TE-44, alcohol injection, MJ stretch, 3" DP, adj FP, blue tops and Red's fuel pump.  I'm going to upgrade to champion irons and a cam.  Probably also go with propane injection and a maf less ME setup once the bugs are worked out.  Having a local shop with limited Buick knowledge do the cam and heads for me.  In an effort to avoid break-in and wiped lobe issues, I thought I'd go with a roller.  Would appreciate any suggestions regarding cam and vendor.  Approximate cost would help too.  Ultimate goal is 11.99 in street trim and pump gas.  Thanks!
