turbodave231
Moderator
- May 24, 2001
What do the two IAC gain "P" and "D" parameters control?
I'm guessing they control the rate at which the IAC pintle moves. BS3 has IAC proportional gain and derivative gain. Are these the same?
What is the typical range for these two parameters?
The engine seems to be a little slow with IAC/idle speed corrections. I bumped up the throttle follower parameter and that helped.
I currently have the "P" at 33 and the "D" at 11
