I called fast and they instructed me to wire 12Volts to pin L2 and when I look on the FAST "dashboard" I see the N20 enable go from 0 to 1 so I know the computer is seeing the N20 enable. The problem is it does not enable the fuel and or timing maps. I checked and double checked all of the parameters. I was told by fast that the nitrous control was being used by the buick cooling fan relay. But I do not want the fast to control nitrous solenoids, I only want the maps to enable and Fast said 12v to pin L2 would do this. I am not sure so any help would be greatly appreciated. Thanks :biggrin:
