Cleaning out the shop, misc parts for sale cheap.
Steve
I am in the process of cleaning out my shop and I am looking to sell some parts cheap. All prices are plus shipping unless noted. Please add 3% or send as a gift if using PayPal. Thanks
200r4 trans pan with drainplug added $20
ATR 3” stainless test pipe $20
Remflex header gaskets(new) $23 shipped
GM stock flexplate $20
IAC housing with sensor $15
Modified turbo cover-cut for after market downpipe and has hole in the front for oil line $20
Stock up pipe with holes for dual nozzle Alky $15
New JE piston rings for .010 over $20
Rear speaker support brackets $15
Low mileage stock injectors with 2 stock chips $35
Stock front upper controls arms in good condition $40
2 OEM coilpacks with modules, I was told they were good when I bought them but never tested them $50 for the pair
1 Type 2 coil pack and module, told it was good but untested $25
Rear seat belt set up from a GN $20
Stock air boxes(2) $10 each
Top gray ECM kick panel cover from a GN $20
NOS in the package GM pull strap screw cover, only 1 of these $10 shipped
NOS in the package bag of GM rocker shaft plastic spacer buttons. $15 shipped
Passenger side valve cover with push in K&N breather from the front. This cover looks exactly stock except it has a removable oil cap on it. It came from a different Buick car but I can’t remember which one. $20
Set of OEM core support to fender braces. $20
I'll take the NOS in the package GM pull strap screw cover.
Just to confirm, this the cover over the screws holding the door pull strap in the correct grey for the GN. Correct?
Thanks!
Thanks!
That’s correct. I will PM you.
Can i see the coils and modules?
Here a couple of pics of them. I believe that the modules are OEM, but I am not sure about the coil packs.
2nd in line behind GNmaster2004 for the " 2 OEM coilpacks with modules, I was told they were good when I bought them but never tested them $50 for the pair".
How's the condition of the rear seat belts
Also interested in the IAC sensor. What condition is it in? New ? Fairly used ?
GN rear seatbelts. I’m interested. What kind of condition are they in? Thanks
I wouldn’t classify them as good condition. Everything functions properly, and they are not frayed. They could use a good cleaning.
In line for test pipe, whats the length. Any pics?
The test pipe is about 17” long. It had a evac fitting welded to it but it can be capped or welded up if desired.
