T
TK65
Guest
I own a 1987 GN with 47,000 miles. Recently it started producing a cliking noise from the transmission that appears to be related to rpm. The niose is louder when the gear lever is in 1, 2, or R. It as also louder when the TV cable is pulled. A pressure gauge showed the presure fluctuating radically. The needle was a blurr. It still drives OK, but I'm keeping driving to a minimum. I think it may be related to a problem with the transmission pump or the valve body. Any ideas?![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
