climate control
hcox10
hi
I have a 1984 T-type with electronic touch climate control. The only thing I can get to work is the defroster. Could there be a vaccum hose off somewhere? If that is the case, could someone provide a diagram showing all the vaccum hoses for the climate control. Thanks, Harold
There should be a Vac acuator under the passenger dash area or under center console(right or left side both maybe) I heard it's a vac leak and shoots the air only to windshield(defrost) only. As for Vac line diagram, not on me man.
Tho I would think it's a leak anywhere from the Vac block(passenger side) by the MAP sensor(passenger fender wall) from there to the acuator under the passenger dash by the firewall.
Your "blend door" lever is probably broken. Common problem.
