OK guys I think I am kind of screwed on this one but I figured I would consult the guru's here. I had a gas tank develope a tiny hole in the bottom of the tank. The car was being stored under cover but outside for about 4 years. When I started getting the car back up and running the tank/fuel pump were replaced. But since the new tank went in I have this weird pressure build up in the tank when I remove the gas cap.
I finaly figured out what was up. The vent line that goes to the carcole canister is completely blocked with corosion. I removed the tank and got the 18-20 inch peice of metal vent line cleared that sits directly over the tank but the hard line that runs from just above the axle to the engine bay is blocked also. I used a piece of wire to snake through the small line and compressed air to blow it out but this is not going to work for the long run. I was hoping that someone knew of a miracle rust dissolver that I could work into this line and maybe clear the blockage. Looks like there are products out there but most are for removing rust from areas that you can get at and sand/prep etc. Thanks -Patrick
