What closed loop gain values are you guys running? 160# injectors......I am helping someone with a 231in 109 motor and the AFR is up and down like a yo-yo. It goes from 8.5:1 to 13:1 or so..... 02 correction is up and down as well.... just slower than the actual AFR.
I realize these are some big honking injectors for a 231 in motor..... but it is either these or 72's ......problem is the 74GTQ turbo will suck those dry pretty quick. I figured if I could get it to idle.... the rest would be fairly easy......
Oh... to further complicate the tune.... the car is running alky as well.... My VE table numbers generally get higher until about 200kPa... then taper off above that due to more and more alky progressing in..... so far we have been mainly tuning from 18-20 psi boost.
I am not wanting to go more until we get the yo-yo under control.
