Oct 26, 2015 #1 N NY87GN Member Joined Jul 3, 2013 Messages 193 Just wanted to get everyone’s opinion, how do you close your door when in car.. Armrest or strap? Why?
Oct 26, 2015 #2 salvageV6 Daily Driver Joined May 25, 2001 Messages 21,016 Both, but usually the strap. Easier to grab.
Oct 26, 2015 #3 TexasT Texas, Where are you from Joined Sep 10, 2002 Messages 7,209 Armrest. Ive pulled the strap off and it just seems easier with armrest than fixing the strap. Sent from my HTC PH39100 using Tapatalk
Oct 26, 2015 #4 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 Arm rest. Using the strap the screws eventually come loose and it breaks the molding on the door.
Oct 26, 2015 #5 626gn Well-Known Member Joined Feb 15, 2009 Messages 2,696 mikestertwo said: Arm rest. Using the strap the screws eventually come loose and it breaks the molding on the door. Click to expand... X2
Oct 26, 2015 #6 A aminga Chicks Dig the powerbulge Joined Dec 15, 2003 Messages 5,578 I used to use the arm-rest. now I pull on my straps without fear. http://turbobuick.com/forums/threads/how-to-fix-loose-pull-straps.401965/
Oct 26, 2015 #7 R Roc87 11 Second V6 Joined May 25, 2001 Messages 2,997 aminga said: I used to use the arm-rest. now I pull on my straps without fear. http://turbobuick.com/forums/threads/how-to-fix-loose-pull-straps.401965/ Click to expand... That's what the factory should have done. I've done this fix yet still use the armrest only from habit
Oct 27, 2015 #8 G GNVAIR Member Joined May 24, 2001 Messages 2,449 The armrest. After having people repeatedly ripping out the pull strap I had these made.
Oct 28, 2015 #9 W whitehot1 Well-Known Member Joined Oct 24, 2006 Messages 4,682 I use both ways. I never gave it a thought before, never had a favorite way of closing the door. But as long as the mounting screws are tight it shouldn't be an issue.
