TType85
- May 25, 2001
I just got word back on my Art Carr 19930 9" N/L torque converter and it turns out it was ok. They are tightening it up a bit, but everything inside checked out A-OK.
Now i'm really wondering whats going on.
Heres the symtoms/problems.
From my directscan logs the car is turning 4900 rpm to turn 75mph and 5200 to turn 90mph (trapped 92mph in the 1/8, 5375rpm). I am running a 25.7" tire (nitto 275/50/15) and 3.42 gears.
According to a few calculations I am seeing 21% slippage at 90mph, 30% at 75mph.
Others i've talked to with AC 9" N/L are seeing 10% slippage with the same calculations.
Since the converter checked i'm trying to figure out what it could be. One suggestion that came up is that the clutches in the trans can become glazed (before they go out completly) which if thats the case they could be slipping as I apply more power (which points to my original problem where i'd turn up the boost but run the same MPH)
any suggestions?
I have a spare trans sitting in the garage, but it only had a "street rebuild" so I don't know it it will hold up to many passes....
any suggestions?
