Hadn't driven the Jeepster for a week or so - and when I parked it everything was fine. Started it up yesterday to take my kids to swim lessons and it wouldn't idle. CEL came on - check the scan master and sure enough code 34 showed up.
Can the MAF just go bad from sitting? Will taking it out and spraying MAF cleaner help - or is it more than likely just toast? Any other things that can cause this? I limped it to the pool as it it only a mile away by feathering the gas very lightly and holding the gas pedal down slightly while braking.
No milkshake. Pump gas, no alky and boost is limited to 14psi.
