ScottHeidinger
 - May 2, 2015
You can reset the ECM now or later. Seems like you're chasing fuel. My guess is that the rail gauge is not correct and the rail doesn't have enough fuel pressure since it ran good showing much higher pressure but if the pump isn't producing enough volume at that pressure it could be a pump issue. The gauge you can read inside the car should help you see if the rail pressure rises with boost
