must be an old chip with stock format or stock chip as most aftermarket chips (like the turbo tweak chips) already have that flag turned off allowing removal of the boost solenoid without worry of SES lamp or code popping up
you could connect a restistor across the boost solenoid terminal s to satisfy the ecu or jut connect a solenoid and leave it unhooked from vac lines
