Well finnally got my jem up and running and got the Turbolink up and running as well(very useful in setting IAC and TPS) drove down the road and started getting codes and when I say codes I got eveything from calpak not found to water injection to vss to esc signal ,boost sensor,o2 rich,o2 lean,os circuit failure,maf,mat and the list goes on and the car runs like crap so In the shop check every lovin last ground no problems so I was thinking either a bad chip or bad ecm car has never really run great since the 87 ecm conversion so I
ordered a chip from eric and ran a little bit better but now wont even spin a tire
Next question can the cam sensor be installed 180 degress out and the car still run?
Next step was to reset computer and run again to see if code came back Hell never even left the garage and they started popping up put the car in reverse and got water injection code followed by vss,then IAc, ad converter and so on didnt even move 10 feet car seems to run better with turbolink disconnected but that may just be me
So what does everybody think bad chip or ecm
