Greg,
Before you spend $ on a Coil and Module I would suggest taking the Coil pack off, and checking your connections. You have have a loose/dirty connection, and this would cause your issue.
Pull of the coil pack using the Torx Heads screws, and look at the connections for #2 and #5....those were the ones that showed up weak when we put the coil pack test on it.
