coil pack
greg lott
is there a upgraded coilpack/ignition mod on the market if not whoose is the best i bought 2 used ones only to have them fail also should both be replaced together?
Greg,
Before you spend $ on a Coil and Module I would suggest taking the Coil pack off, and checking your connections. You have have a loose/dirty connection, and this would cause your issue.
Pull of the coil pack using the Torx Heads screws, and look at the connections for #2 and #5....those were the ones that showed up weak when we put the coil pack test on it.
Kirbans has stock coil packs for 49. Seems to be a decent price. Put one on mine with no problems.
