Coil Pack
B
BLACKNESS
Guest
How can I test my coil pack to see if it is bad? Thanks.
With an ohm meter check the resistance between the front and rear terminals of each corresponding coil pack. They should each be between 11,000 and 13,000 ohms.
Best and most reliable way is to borrow or buy Caspers coil pack tester...will tell you whether the coil pack or module are bad...invaluable tool IMO...
The resistance method will find really bad ones but may not dig out the flaky ones.
The coil tester should catch at least 95% if not all.
