Replacing old shocks/springs with new ones. All the old parts are removed. I have the 2 Lower Control Arm bolts removed from the frame. Spring is in the pocket and shock bolted up. Castle nut on Lower Control Arm/Spindle is on threaded just a bit. All I need to do now is line up the Lower Control Arm to frame and secure the 2 bolts. I am having a hard time lining that up. Any tips/tricks?
Thanks.
Thanks.
