They did a nice thing with the XDI design, provided a seperate EST line for each coil pair on the DFU. Some OEM's did this as well with their waste spark modules; too bad Buick didn't. This eliminates the insufficient dwell time at high rpm limitation of the stock CCC3, which has only a single EST line that must serve all 3 coil pairs. Thus Electromotive can claim to get full coil charge time all the way up to 9600 rpm on a v6 setup, because they can command each coil pair to start charging independently.
They run a 60-2 CRS, which gives them crank reference postion information every 6 deg CAD. F*rd also has a 60-2 setup (and 30-1) for awhile now.
If the XFI for example could be configured to run 3 seperate EST outputs, then we could swap the stock Buick CCC3 ignition module for the 3 coil Electromotive DFU module and have a nice, stock type ignition power upgrade for race engines, with full coil power up to 9600 rpm. And FAST could make the 2 step and all work with it too. Seems that would be nice.
TurboTR
