Collapsed stock motor mount
wb's87
willrock
The motor mount on passenger side is collapsed the rubber is tight up against the bolts that hold the motor mount to the block. I can't get a socket on to remove the bolts. Any suggestions?
Thank you in advance!
I was thinking of that. Any suggestions on what to use or how to do it? Very tight quarters as I am sure you know. The rubber is like rock hard.
brand new razor blade, be careful. possibly several since they will dull quickly.
Thanks for the replies. I got it off by slicing away with the razor blade. I was very surprised how easy it actually was. New mounts are installed. Yay! Thanks again you guys and this site are awesome!
