The weber cams come from comp cams and then the nose of the cam is machined to accept the roller thrust bearing and cam sensor drive parts that are specific to a Weber set- up.
I am not sure if the pieces you now have would work or not..... If they were not done by weber then they likely will not work on these cams.
Post up pics of what you have and I can advise you better. FBR.
