This The Complet Motor Out Of My Car,made 520 Hp On Chassis Dyno And Ran 6.49 In 1/8.took Car To Track 3 Weeks Ago And The Vacumn Line Came Off Of The Map Sensor And Melted A Piston,bearings Did Look Real Good From All The Detonation,motor Is Completly Apart For Inspection,109 Block With Billet Caps,champion Cnc Ported Irons With 130lb Springs,harland Sharp Rockers,champion Ported Intake With 83lb Injectors And 70mm Throttle Body,reed 224 Cam,selling Everything Together,modded Ecm With Max Effort 16 Position Thumbwhell Chip,3 Bar Map Sensor,heated 02 With Caspers Harness,motor Needs 1 Piston And I Would Use A Differnt Crank Because That One Was Already 20 Under,intake To Pan With Computer $2800
Any Questions Call Johnny At 803-206-6468
