TRBOLeSABRE
GMeister
- Aug 13, 2007
I have a complete refresh engine out of my 79 lesabre sport coupe. It had 45k on it before i had it honed. It has new rings, rod and main bearings, turbo gaskets, engine gaskets, HV oil pump, water pump, front oil and water pump housing, smog pump, high amp alt, working ac comp, fuel pump, carb, dist, valve seals, everything has been degreased and painted. Its going to be fired up hopefully sun, depending on my work schedule. I have 95% of the recipts for the parts,i may be able to find them all. It has flawless manifolds, crossover pipe, and operational pevr, and efe/egr vaccuum switch along with egr valve. I have the ESC also which works also. This is entirely complete. I owe my machine shop alot of money so this has got to go. Im working on an olds 403. all acc come with. i can send pics. email is kingphaticus4u@hotmail.com im in buffalo ny. I must mention that the turbo has one broken bolt on the exhaust side that i tried to extract, but it broke the ez-out. It has no effect on the performance becase it still makes a good seal. You can cal me for more details 716-380-0730. My name is steve and the best time to call is before 3pm.
