RICHIE HIGH PSI
- May 25, 2001
How far off 60 do you live?
SignUp Now!I'm startin to think i have a broke wire, guess i need to check all the stinkin wiring to the ccci.
Quick question i keep hooking up my coil or ignition module tester from caspers and it doesn't do anything this is with 2 different coil packs (1 is from caspers) and 3 different ignition modules and it still does nothing why? i guess i'm calling caspers in the morning i just find it hard to believe that with all these they are all bad but someone told me it wouldn't work on these aftermarket ign modules does someone have one that knows for sure (the ign module i have now is from NAPA).
Well it least that narrows that down thanks snksknr, i put a test light on the injector it lights up when i crank it gets dim and bright not sure if this would be a pulse or not this thing is gettin me down, just ohmed crank and cam sensor wires to the ccci and they are all good.:frown:
