SignUp Now!John, when time allows can you please take a close up pic of the rear wheel well molding mod you did. you stated you cut the lip off and welded a 3/8 brake line. I am very curious how it looks.
thanks and incredible job!
Looks Great! What size wheel / tire combo is that with what backspacings? That's the look I always wanted on my GN-maybe some upgrades are in the near future.
That is a very nice build. Thanks for sharing. Is your dual fan set up the Spal fans and shroud package from Mark at TRcustoms or is that custom? Also, noticed that you kept the stock underhood light. lol
Here's something you rarely see on turbo buicks, a wastegate that dumps into the atmosphere!! I love it and once I get a new turbo definitly going to have to make one
What radiator/fan combo is that?
Griffin Radiator...It came as a kit with aluminum shroud, Spal Fans and wiring harness.
Hows the fit, everything looks like it fits perfectly! Do you have a part number?
Fit is good, I did have to make a few modifications. I had to widen the lower radiator tray, I ordered a thicker core. Griffin has three different cores for the Regal. I believe they make a direct bolt in that is the same thickness as the stock radiator, no modifications required. The other two are thicker and require a little modification.
Part # 6-585EA-BXX...This was the part number I was given, it's was rated for around 600hp. The one below(direct bolt in) was rated for 400hp, the one above mine(1/2" thicker) was rated for 800hp. I also deleted the trans. and oil coolers provisions on the radiator, as I have aftermarket coolers.
Nice. How about the aluminum fan shroud etc?
The aluminum shroud, fans and wiring kit came as a complete unit from Griffin. The part # I post above was the reference number given to me. I believe these radiators are listed under Griffin's Universal Radiator's on their website.
Ah ok. Sorry for the million questions, that shroud just looks nice. So I am assuciming that if you went with the smaller radiator, everything would fit with no mods?
