after i wasted the timing gear(at a decent RPM) i replaced the timing chain set and car won't start just fouls the plugs did a compression test and here's the results, if I only lost 2 cyl's then it should run, (poorly) right? only thing I could have screwed up was the cam sensor install but I followed the procedure very closely and the voltage check was right on the money, and the gear dot's lined up the only plug that was not wet fouled was number one, it was dry
#1 180
#2 185
#3 180
#4 0
#5 105
#6 180
#1 180
#2 185
#3 180
#4 0
#5 105
#6 180
