computers
kcs387
OK any one now what computers out of any other car will work in the turbo Buick or what part number. If any others will work.
1986 NA 3.8 SFI is the same. Only 1986. GM #1226459. Used in Park Ave.Electra,LeSabre,Riviera,Century,Olds 88/98,Toronado,Ciera.
Eric, I thought GM part number: 1227148 would only work in our cars? The other part number you listed above will work too? That part number is only good for 1986 model years?
Thanks for clearing this up, Craig
You're correct. 1227148 is the number. That other number was for a hot air I was screwing around with.
I never saw a 1227148 in a Riv or Toronado.
Best bet is the front-drive full size 86 Buicks and Olds with 3.8s.
Right you are John. I wonder why a Rivonado ECM wouldn't work in place of the 1227148? It might be something as simple as a BCM(Body Control Module) interface feature. I dont see to many 86-87 Rivs in the boneyard so it may be awhile before I see what the actuall difference is. Either that or when I find the time I can look in the FSM and find something there.
man, you are confusing me...
so,
1226459 is wrong
and
1227148 is correct?
Here is a cut and paste from Ed's post on the "other" board:
ECM pn# 1227148 Here is a listing of all that use it:
1989 PONTIAC FIREBIRD TRANS AM V6 3.8L 231cid GAS FI T Engine VIN = 7
1989 PONTIAC FIREBIRD TRANS AM GTA SE V6 3.8L 231cid GAS FI T Engine VIN = 7
1987 BUICK REGAL GRAND NATIONAL V6 3.8L 231cid GAS FI T Engine VIN = 7
1987 BUICK REGAL LIMITED V6 3.8L 231cid GAS FI T Engine VIN = 7
1986 BUICK CENTURY CUSTOM V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK CENTURY ESTATE WAGON V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK CENTURY LIMITED V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK CENTURY T-TYPE V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK CENTURY V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK ELECTRA PARK AVENUE V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK ELECTRA T-TYPE V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK ELECTRA V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK LESABRE CUSTOM V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK LESABRE LIMITED V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK LESABRE V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK REGAL GRAND NATIONAL V6 3.8L 231cid GAS FI T Engine VIN = 7
1986 BUICK REGAL T-TYPE V6 3.8L 231cid GAS FI T Engine VIN = 7
1986 OLDSMOBILE 98 REGENCY V6 3.8L 231cid GAS FI N Engine VIN = B
1986 OLDSMOBILE 98 REGENCY BROUGHAM V6 3.8L 231cid GAS FI N Engine VIN = B
1986 OLDSMOBILE CUTLASS CIERA S V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 OLDSMOBILE CUTLASS CIERA V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 OLDSMOBILE DELTA 88 ROYALE V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 OLDSMOBILE DELTA 88 ROYALE BROUGHAM V6 3.8L 231cid GAS FI N Engine VIN = 3
