I using head bolts not studs.  I changed the oil again yesterday and went for a drive.  Not too much boost just wanted to see if the condensation would burn off with more heat in the motor.  Since I pressure tested the cooling system and it passes I felt this was worth a try.
TT/Ameasap  Bo Evans called me right before I left and talked me though a few things that he's experienced with this same issue so I knew it was possible to have this condition and live though it.  I may still have a problem under boost so I will try that today.  I had Sandy and the daughter in the car yesterday so I don't mess around with them in the car.  I did a burn out one time with my Trans Am and scared the hell out of the daughter so she wouldn't ride in the car anymore.
No more milky stuff in the breathers or catch can.  I drove 30 miles and stopped for a beverage.  Checked oil, breathers and catch can.  All good but catch can had pure water in it so I drained it.  Drove another 20 miles and stopped for a beverage.  Repeated process, all good but maybe 5 cc's of pure water in catch can each time.  Drove 40 miles and stopped for a beverage.  Same story.
Checked radiator at every stop.  Coolant was warm as expected but radiator cap was cool? and no pressure when I opened it each time.  Could be the cap because I have the pressure tester on the car pumped to 14 psi as I type this and it's holds pressure.  The coolant was about 1 to 2 inches below the cap before I left.  It's a little lower this morning but I just did the crank seal and the coolant could just be finding it's happy place.  I did stick the nose of the car in the air yesterday and bled the system before I left.
Drove with a couple buddies yesterday who followed me and said nothing came out the tail pipe all day and they also felt the fluid out of the catch can.  Pure water.  No residue left over on your skin, just dries up like water.
Here is a video I took this morning.  We drove about 50 miles to get home and parked the car in the garage.  Drove it to my dealership this morning and this is how much water was in the catch can.  Less than the previous times.
Now the question still remains on how did I get that much water in my motor?  Weather and short trips?  Could be.  I drove it in the rain and I have a Tomko CAI and the filter is right behind the front bumper, sucked it in the motor?  Could be.  I was chasing oil leaks and added oil dye to find the leak.  I used engine degreaser in a can and rinsed the motor off with low pressure water.  I did cover my breathers with plastic bags.  Could I have gotten water in the motor doing that?  Could be.
The jury's still out so I will drive it more today and see if I dry up completely.  I getting closer.
