Pulled the intake tonight. Looks like it was leaking at the passenger front. There was moisture around the gasket there at the head and none of the others. There was coolant sitting in the block up by the lifters and none at the rear of the block. I took some pictures that I'll post tomorrow. I didn't see any failure in the gasket, no cracks, no signs of it being unseated or deformed etc. I pulled the thermo and dried up as much coolant as I could with paper towels before I pulled it so I didn't spill any. There was more in the front of the valley of the engine than could have spilled so I'm confident that's where the pressure blew the coolant. I also drained the block of coolant.
Now to show you guys I'm a good sport I'll tell you a funny story. I have no ego when it comes to wrenching and I always try and leave my vanity at the door.
Here it goes. We pressured the cooling system this morning and heard all kinds of air leaking at the intake etc. This is in my man cave at the dealership in the back shop. My buddy Rich left and I went back to my real job running the dealership. I guess I left the valve open on the tester and the air compressor must have been full of air. I go back to the man cave at 5:30 pm ish (6 hours later) and put the car in the air and grabbed my wrench to take the coolant plug out of the block. Had a little music playing, cracked a beer, swept the floor, cleaned all the work benches and organized myself to pull the intake. Shop looked awesome and the floor is spotless. Grab a few tools and rolled them over to the car on the tool cart and life is good. I love shop time by myself. Cracked that plug a few turns and that sum bitch flew out the motor at 70 mph with a gallon of coolant and kept coming because I had all kinds of air left in the compressor tank. I'm helpless because the cars in the air, can't shut the valve off so I just stand and watch, can't see for sh&t cause I got coolant in my eyes running down my face but it was quite the deal.
Cleaned up and grabbed another beer.
Now back to serious business.
I am going to build some steel plates to block the coolant passages in the heads and check for head gasket issues. Earl or anyone who might know, how much pressure should I put to it? I guess 20 psi would do it if the leak was in the head gaskets since that's all it took today to have air leaks but how far can I go with air pressure until I give up if no air leaks?
Second thing I'm going to do to put my mind at ease is pull the pan and check a few bearings.
Once I get this thing back together or maybe before what do I want to do to flush the coolant out? In the past after changing intakes I just did a couple of oil changes right away but maybe there's something bigger and better that I can do? The motor wasn't running when the coolant ran in the crankcase. However I found more white goo under the intake and at the back of the block in the lifter valley which I expected.
Any advice at this point would be appreciated.
