ALVAROG1983
EVIL GN
- Mar 27, 2007
Quick Question Why Would People Put There Turbo Oil Drain Back In The Oil Pan Instead In The Block Stock Way.
SignUp Now!Some guys have so much busyness under the hood with racing setups the only straight shot they can get is the pan. Its acutally a much better place anyway as long as its above the oil level in the pan.
WHY DO SAY ITS MUCH BETTER I HAVE THIS KIND OF SET UP BUT ITS A PAIN TO GET TO THE PAN AN FITTING. SO I FEEL LIKE JUST CAP IT OFF AND RUNNING IT BACK TO STOCK LOCATION.
Because your dumping the oil back in the pan where it should be and preventing it from getting caught up in the rotating assembly. The oil coming out of the turbo is very aerated. Also the stock tubing is barely adequate for the oil return.
Exactly, you guys look at some race set ups and the valley is almost completely closed off so that oil does not slam into the rotating assembly as it drains from they valley absorbing power as it powers through that falling oil.
So for many of the reason listed above and most importantly to me the reasons listed in Bison's post I would always rather have the oil from the turbo routed straight to the pan. On my set up which is experimental and a learning project, I am scavenging the turbo with one stage on my external Johnson Pump.
