AdammRyan
87 t top
87gn is coming back from T-top repair and I want to start working on suspension. Car will be both driven around town and taken to strip hopefully semi regularly. Car is full weight. Will be in the 600s to the ground.
Right now for the rear:
I have Viking Warrior Rear Double adjustable coil overs with 12 inch 150lb springs and HR Parts rear sway bar upper and lower control arm package.
Looking for opinions for the front. I would like to get Viking coil overs up front too. I was recommended by them (Viking) to get the warrior or berserker in a 350lb spring. I was also told by a different vendor that spring would be to light and was recommended to get a 450lb spring. They gave a few vendors for control arms and this is where I would like help too. I was recommended UMI, Trick Chassis, Global West, CPP, and Smith etc.
Was looking at Trick Chassis G Body A-Arms Coil over Part #TC480
It says no sway bar mounts which my car has a front sway bar. So admittingly as a new person to this... Does that mean running with out front sway or it will have to be fabbed to mount elsewhere?
Any overall help or opinions on this would be great. I have searched through forum some what but thought id be more direct with questions.
Thanks in advance,
Adam
Thanks in advance,
Adam
