Scott89TTA
- Jul 12, 2005
I know my setup isn't optimal but the plan is to deal with it until I could afford to do the heads and cam. I have only run the car a few times with my current mods (see sig, not listed 100# springs installed) and so far have not yet locked the converter. A lot of people keep asking me if I have locked the converter yet...telling me I will improve my et a little pick up a some more mph ? When and how should I lock the converter? Also would my current setup benefit from raising my boost from 24 to 25 or 26 ? I'm guessing the stock heads and cam aren't going to do much more...the heads do have come very light porting (more gasket matching then anything) that I did while they were off replacing the head gaskets, also cleaned up the exhaust side and header welds as well.
Using the trans brake the converter spools the GT6776e pretty good but just driving around on the street it isn't bad but is a little sluggish until I get it spooled up...I figure heads and a nice roller cam will cure that when I am ready. I am using tractor fluid as recommended do to the StageRite trans brake.
here is a thread on my best runs to date http://www.turbobuick.com/forums/tu...est-tune-mason-dixon-dragway.html#post2341673
